주요 콘텐츠로 건너뛰기
Canon PowerShot SX260 HS LCD Screen Replacement
필요한 것
  1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/3 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: 1 단계, 이미지 2/3 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3/3
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 (3 mm) screws on the left side
    • Remove the 2 (3 mm) screws on the bottom of the camera.
    • Remove the 2 (3 mm) screws on the right side of the camera.
  2. Canon PowerShot SX260 HS LCD Screen Replacement: 2 단계, 이미지 1/1
    • Use your plastic opening tool to gently lift and remove back face plate.
    • Unplug the ribbon cable leading to the mode dial.
  3. Canon PowerShot SX260 HS LCD Screen Replacement: 3 단계, 이미지 1/1
    • After removing exterior screws, gently lift off the front face plate with your fingers.
  4. Canon PowerShot SX260 HS LCD Screen Replacement: 4 단계, 이미지 1/1
    • Remove the 4 (3 mm) screws that are under the face plate.
  5. Canon PowerShot SX260 HS LCD Screen Replacement: 5 단계, 이미지 1/1
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  6. Canon PowerShot SX260 HS LCD Screen Replacement: 6 단계, 이미지 1/1
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  7. Canon PowerShot SX260 HS LCD Screen Replacement: 7 단계, 이미지 1/1
    • Next,take off the 2 (3mm) screws on the back side of the camera to remove the dial panel.
    • Gently lift the panel with your fingers.
    • Be careful not to rip the attached yellow ribbon cable.
  8. Canon PowerShot SX260 HS LCD Screen Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully unplug the yellow ribbon cable from the front of the camera using your tweezers.
  9. Canon PowerShot SX260 HS LCD Screen Replacement: 9 단계, 이미지 1/1
    • Gently slide the LCD screen to the right and remove.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tyler Kelch
회원 가입일: 03/05/15
622 평판
안내서 4개 작성하였습니다
Sam Houston State, Team 11-8, Blackburne Winter 2015 Sam Houston State, Team 11-8, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G8
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 31
전체 시간: 3,763
