주요 콘텐츠로 건너뛰기
Canon PowerShot SX280 HS LCD Screen Replacement
필요한 것
  1. Canon PowerShot SX280 HS LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Turn off the camera and remove the battery.
  2. Canon PowerShot SX280 HS LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the two 3.4 mm screws on the left side of the camera.
  3. Canon PowerShot SX280 HS LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Using the same screwdriver, remove the two 3.4 mm screws on the bottom of the camera.
  4. Canon PowerShot SX280 HS LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the small plastic tab, located on the front of the camera, to remove the GPS cover.
  5. Canon PowerShot SX280 HS LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Using the same Phillips screwdriver, remove the two screws that hold the LCD screen.
    • Remove the other small tab attached to the LCD screen.
  6. Canon PowerShot SX280 HS LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • When removing the plastic casting, do not pull it all the way off. Detach the small tab first and make sure nothing else is attached to the casing.
  7. Canon PowerShot SX280 HS LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • To remove the tabs from the camera, remove all screws.
    • Slowly lift the screen out of the camera using the tabs.
  8. Canon PowerShot SX280 HS LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Use the tabs, outlined in red, to slowly remove the LCD screen.
    • Remove the screws to remove the camera motherboard.
  9. Canon PowerShot SX280 HS LCD Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Insert the replacement LCD screen.
    • Ensure that the long strip is attached to the original position.
  10. Canon PowerShot SX280 HS LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • To reassemble your device, follow Steps 2 to 9 in reverse order.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Osmand A Munoz
회원 가입일: 03/23/15
228 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-5, Miles Spring 2015 UMass Dartmouth, Team 1-5, Miles Spring 2015 회원
UMASSD-MILES-S15S1G5
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 33
전체 시간: 2,634
