소개
Replace the func. set turn dial of the Canon PowerShot SX50 HS.
필요한 것
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
Remove the four Phillips #000 screws, length 3 mm, attaching the metal panel to the inside of the back encasement.
다른 2명이 해당 안내서를 완성하였습니다.
2 Comments
Interested to know where I can buy the switch/ribbon assembly for that function dial?
Liz Comery - 답글
I appreciated the clear instructions and photos. Couldn’t be any better. Now I would like to know where to purchase the dial assembly.
