주요 콘텐츠로 건너뛰기
Canon PowerShot SX520 HS LCD Screen Replacement
필요한 것
  1. Canon PowerShot SX520 HS LCD Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS LCD Screen Replacement: 2 단계, 이미지 1/1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: 3 단계, 이미지 1/3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: 3 단계, 이미지 2/3 Canon PowerShot SX520 HS LCD Screen Replacement, Back Face: 3 단계, 이미지 3/3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS LCD Screen Replacement: 4 단계, 이미지 1/1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS LCD Screen Replacement: 5 단계, 이미지 1/2 Canon PowerShot SX520 HS LCD Screen Replacement: 5 단계, 이미지 2/2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS LCD Screen Replacement: 6 단계, 이미지 1/1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS LCD Screen Replacement, LCD Screen: 7 단계, 이미지 1/1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS LCD Screen Replacement: 8 단계, 이미지 1/1
    • Carefully pop out the LCD screen with your fingers.
결론
Lisa Choe
회원 가입일: 09/22/15
460 평판
안내서 3개 작성하였습니다
Baylor, Team 4-4, Williams Fall 2015 Baylor, Team 4-4, Williams Fall 2015 회원
BU-WILLIAMS-F15S4G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 913
