소개
Does your screen flicker or simply not turn on? Replacing the LCD screen may solve the problem.
필요한 것
Using your fingers, slide the battery compartment door to the right until it unlocks.
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
거의 끝나갑니다!
결론
