소개
This guide will show how to remove the metal plate that leads to the inside of the camera. This will allow access to the lens and motherboard.
필요한 것
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
After all 8 screws are removed, pull the metal plate out with your fingers.
