주요 콘텐츠로 건너뛰기
Canon PowerShot SX530 HS Back Panel Assembly
필요한 것
  1. Canon PowerShot SX530 HS Back Panel Assembly, Canon PowerShot SX530 HS Back Panel Assembly: 1 단계, 이미지 1/2 Canon PowerShot SX530 HS Back Panel Assembly, Canon PowerShot SX530 HS Back Panel Assembly: 1 단계, 이미지 2/2
    • Flip over the camera.
    • Use a Phillips PH000 to remove the two 4mm screws near the center of the camera.
    • Use a Phillips PH000 to remove the two 6mm screws on the ends of the camera.
  2. Canon PowerShot SX530 HS Back Panel Assembly: 2 단계, 이미지 1/2 Canon PowerShot SX530 HS Back Panel Assembly: 2 단계, 이미지 2/2
    • Locate the left side of the camera.
    • Use a Philips PH000 to remove the two 6mm screws.
  3. Canon PowerShot SX530 HS Back Panel Assembly: 3 단계, 이미지 1/2 Canon PowerShot SX530 HS Back Panel Assembly: 3 단계, 이미지 2/2
    • Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
    • Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
    • Use the Phillips PH000 to remove the 4mm screw near the USB port.
    • Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
  4. Canon PowerShot SX530 HS Back Panel Assembly: 4 단계, 이미지 1/3 Canon PowerShot SX530 HS Back Panel Assembly: 4 단계, 이미지 2/3 Canon PowerShot SX530 HS Back Panel Assembly: 4 단계, 이미지 3/3
    • Rotate the camera to locate the side with the LCD screen.
    • Use a Phillips PH000 to remove the two 6mm screws above the LCD screen.
    • Once the screws are out the back panel, it is ready to be taken off. Grip the backside of the camera and pull it away evenly on every side. The backside must come off straight from the front.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Xavier Patrick
회원 가입일: 02/02/17
481 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-4, Blackwell Spring 2017 USF Tampa, Team 16-4, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G4
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 962
