주요 콘텐츠로 건너뛰기
Canon PowerShot SX60 HS Side Panel Replacement
필요한 것
  1. Canon PowerShot SX60 HS Side Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Side Panel Replacement: 2 단계, 이미지 1/2 Canon PowerShot SX60 HS Side Panel Replacement: 2 단계, 이미지 2/2
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
  3. Canon PowerShot SX60 HS Side Panel Replacement: 3 단계, 이미지 1/2 Canon PowerShot SX60 HS Side Panel Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Side Panel Replacement: 4 단계, 이미지 1/2 Canon PowerShot SX60 HS Side Panel Replacement: 4 단계, 이미지 2/2
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
  5. Canon PowerShot SX60 HS Side Panel Replacement, Front Panel: 5 단계, 이미지 1/2 Canon PowerShot SX60 HS Side Panel Replacement, Front Panel: 5 단계, 이미지 2/2
    • Remove the sunshade located on the front of the lens by twisting it 90 degrees in either direction, then pull straight off the lens.
  6. Canon PowerShot SX60 HS Side Panel Replacement: 6 단계, 이미지 1/3 Canon PowerShot SX60 HS Side Panel Replacement: 6 단계, 이미지 2/3 Canon PowerShot SX60 HS Side Panel Replacement: 6 단계, 이미지 3/3
    • Remove the 5mm Phillips #00 screw located on the left side below the microphone connection.
    • Remove the 4mm Phillips #00 screw located on the bottom left of the camera.
    • Remove the 5mm Phillips #00 screw located on the bottom center of the camera.
    • Pop open the flash and remove the 5mm Phillips #00 screw located under the flash.
  7. Canon PowerShot SX60 HS Side Panel Replacement: 7 단계, 이미지 1/1
    • Remove the front cover by pulling along the lens housing while holding the body of the camera.
  8. Canon PowerShot SX60 HS Side Panel Replacement, Side Panel: 8 단계, 이미지 1/3 Canon PowerShot SX60 HS Side Panel Replacement, Side Panel: 8 단계, 이미지 2/3 Canon PowerShot SX60 HS Side Panel Replacement, Side Panel: 8 단계, 이미지 3/3
    • Remove the 4mm #00 Philips screw located on the top left corner beneath the front panel.
    • Remove the 5mm #00 Philips screw located on the top left corner beneath the front panel.
    • Remove the 5mm #00 Philips screw located on the top of the left side panel near the microphone connection.
    • Remove the 4mm #00 Philips screw located on the bottom left corner beneath the front panel.
    • Using a black spudger, unclip the orange wire ribbon on the lower left corner of the motherboard and then remove it using the nylon tipped tweezers.
    • The side panel is now free and can be removed by pulling the panel to the left.
결론
Tanmayi Ambati
회원 가입일: 07/04/19
76 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 218
