주요 콘텐츠로 건너뛰기
Canon PowerShot SX600 HS Power and Shutter Buttons Replacement
필요한 것
  1. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement, Battery: 1 단계, 이미지 1/1
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 2 단계, 이미지 1/1
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 3 단계, 이미지 1/2 Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 3 단계, 이미지 2/2
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement, Power and Shutter Buttons: 4 단계, 이미지 1/1
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 5 단계, 이미지 1/1
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 6 단계, 이미지 1/1
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 7 단계, 이미지 1/2 Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 7 단계, 이미지 2/2
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 8 단계, 이미지 1/1
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
결론
Jennyfer Munoz
회원 가입일: 02/15/17
411 평판
안내서 3개 작성하였습니다
USF Tampa, Team S6-G4, Lacy Spring 2017 USF Tampa, Team S6-G4, Lacy Spring 2017 회원
USFT-LACY-S17S6G4
3 회원들
안내서 9개 작성하였습니다
댓글 3개
Where does one buy an “opening tool”?
Evelyn Vose - 답글
Where does one buy an “opening tool?”
Evelyn Vose - 답글
Hello Evelyn,
you can buy it in the ifixit store. Otherwise you can use a plastic card you don’t need any more (it will be scratched and or bend afterwards, so you probably better don take a creditcard).
John Maier - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 688
