주요 콘텐츠로 건너뛰기
Canon Powershot A3300 IS LCD Display Replacement
필요한 것
  1. Canon Powershot A3300 IS LCD Display Replacement, Back Cover: 1 단계, 이미지 1/3 Canon Powershot A3300 IS LCD Display Replacement, Back Cover: 1 단계, 이미지 2/3 Canon Powershot A3300 IS LCD Display Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS LCD Display Replacement: 2 단계, 이미지 1/2 Canon Powershot A3300 IS LCD Display Replacement: 2 단계, 이미지 2/2
    • Pull off the back cover.
  3. Canon Powershot A3300 IS LCD Display Replacement, Front Cover: 3 단계, 이미지 1/2 Canon Powershot A3300 IS LCD Display Replacement, Front Cover: 3 단계, 이미지 2/2
    • Pull the front cover off.
  4. Canon Powershot A3300 IS LCD Display Replacement, LCD Display: 4 단계, 이미지 1/1
    • Use a JIS 000 screwdriver and remove the 3.0mm screw from the bottom housing.
  5. Canon Powershot A3300 IS LCD Display Replacement: 5 단계, 이미지 1/1
    • Gently lift the LCD screen off the back of the camera.
  6. Canon Powershot A3300 IS LCD Display Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to pull out the circled brown flat flexible wire from its connection.
  7. Canon Powershot A3300 IS LCD Display Replacement: 7 단계, 이미지 1/2 Canon Powershot A3300 IS LCD Display Replacement: 7 단계, 이미지 2/2
    • Use a spudger to reach under the connecting wire.
    • Gently slide the spudger under the wire and lift the wire off the connection.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kenny Chui
회원 가입일: 10/17/17
122 평판
안내서 1개 작성함
UC Santa Barbara, Team S2-G7, Weedon Fall 2017 UC Santa Barbara, Team S2-G7, Weedon Fall 2017 회원
UCSB-WEEDON-F17S2G7
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 23
전체 시간: 647
