주요 콘텐츠로 건너뛰기
Canon Powershot A3300 IS Motherboard Replacement
필요한 것
  1. Canon Powershot A3300 IS Motherboard Replacement, Back Cover: 1 단계, 이미지 1/3 Canon Powershot A3300 IS Motherboard Replacement, Back Cover: 1 단계, 이미지 2/3 Canon Powershot A3300 IS Motherboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove four 2.7 mm screws, two on each side, from the camera with a JIS 000 screwdriver.
    • Remove one 3.5 mm screw on the bottom of the camera with a JIS 000 screwdriver.
    • When removing the front and back housings, be careful to not break the tabs that hook into the top section of the chassis.
  2. Canon Powershot A3300 IS Motherboard Replacement: 2 단계, 이미지 1/2 Canon Powershot A3300 IS Motherboard Replacement: 2 단계, 이미지 2/2
    • Pull off the back cover.
  3. Canon Powershot A3300 IS Motherboard Replacement, Front Cover: 3 단계, 이미지 1/2 Canon Powershot A3300 IS Motherboard Replacement, Front Cover: 3 단계, 이미지 2/2
    • Pull the front cover off.
  4. Canon Powershot A3300 IS Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 Canon Powershot A3300 IS Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Remove the black cover to expose the motherboard.
  5. Canon Powershot A3300 IS Motherboard Replacement: 5 단계, 이미지 1/2 Canon Powershot A3300 IS Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the shutter button located at the top left of the camera.
    • This will expose the screws that need to be removed.
  6. Canon Powershot A3300 IS Motherboard Replacement: 6 단계, 이미지 1/1
    • Using a JIS 000 screwdriver, remove the 1.2mm screw at the top left of the motherboard.
  7. Canon Powershot A3300 IS Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the 1.6mm screw at the top of the camera.
  8. Canon Powershot A3300 IS Motherboard Replacement: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to pull out brown flat flexible wires from their connection.
    • Remember to gently wiggle the wires from the connection since they are very fragile connectors.
  9. Canon Powershot A3300 IS Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the last 1.2mm screw to pull out the motherboard.
    • The motherboard should freely separate from the housing.
  10. Canon Powershot A3300 IS Motherboard Replacement: 10 단계, 이미지 1/3 Canon Powershot A3300 IS Motherboard Replacement: 10 단계, 이미지 2/3 Canon Powershot A3300 IS Motherboard Replacement: 10 단계, 이미지 3/3
    • Remove motherboard and replace with a new one.
결론
Phillip Chen
회원 가입일: 10/17/17
440 평판
안내서 4개 작성하였습니다
UC Santa Barbara, Team S2-G7, Weedon Fall 2017 UC Santa Barbara, Team S2-G7, Weedon Fall 2017 회원
UCSB-WEEDON-F17S2G7
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 522
