소개
This guide demonstrates how to replace the housing of a Canon Powershot A610. In order to get to the internals of the Canon A610, the plastic casing around the camera must be removed.
필요한 것
Remove the three 3 mm screws that attach the side panel to the body of the camera.
Using your fingernails, pull the side panel outward to remove it.
Remove the two remaining 2 mm screws that attach to the frame of the camera.
다른 3명이 해당 안내서를 완성하였습니다.
