소개
How to remove the front panel.
부품
부품은 필요하지 않습니다.
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment.
  2. Open the CF compartment and remove the top screw The panel, that holds the shutter button and zoom, will come off.
    • Open the CF compartment and remove the top screw
    • The panel, that holds the shutter button and zoom, will come off.
      • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
  3. Unscrew the three small screws on the bottom.
    • Unscrew the three small screws on the bottom.
    • remove the wrist strap
  4. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Remove the screw in the CF compartment.
    • Remove the screw in the CF compartment.
  6. Open the rubber Digital AV Out compartment flap. Pry the battery with the IFIXIT opening tool. Carefully pull out the battery with two fingers.
    • Open the rubber Digital AV Out compartment flap.
      • Pry the battery with the IFIXIT opening tool.
      • Carefully pull out the battery with two fingers.
        • Unscrew the two screws that are now visible.
  7. Starting from the bottom, carefully pull the casing off. The casing will now pivot at the top.
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
      • There are three catches that hold the back casing to the body.
      • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  8. The interior of the camera should look like this.
    • The interior of the camera should look like this.
  9. Remove the two screws at the top of the battery compartment.
    • Remove the two screws at the top of the battery compartment.
  10. With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body. With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
    • With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 2010년 01월 26일
69 평판
안내서 2개 작성하였습니다
Cal Poly, Team 14-40, Regan Winter 2010 Cal Poly, Team 14-40, Regan Winter 2010 회원
CPSU-REGAN-W10S14G40
5 회원들
안내서 8개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 3,970
