주요 콘텐츠로 건너뛰기
Canon Powershot A70 Shutter/Speaker Panel Replacement
필요한 것
  1. Canon Powershot A70 Shutter/Speaker Panel Replacement, Shutter/Speaker Panel: 1 단계, 이미지 1/1
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
  2. Canon Powershot A70 Shutter/Speaker Panel Replacement: 2 단계, 이미지 1/2 Canon Powershot A70 Shutter/Speaker Panel Replacement: 2 단계, 이미지 2/2
    • Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
    • The panel that holds the shutter button and zoom will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Shalan Ertis
회원 가입일: 01/26/10
68 평판
안내서 3개 작성하였습니다
Cal Poly, Team 14-40, Regan Winter 2010 Cal Poly, Team 14-40, Regan Winter 2010 회원
CPSU-REGAN-W10S14G40
5 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 3,230
