소개
The PowerShot A720 is an A-Series camera that features an 8.0-megapixel resolution, high-power 6x optical zoom and is powered by 2 AA batteries. Images are stored on SD memory cards.
This guide provides a step by step instruction on how to replace the battery contacts if the batteries will not power the camera.
Before using this guide, inspect the contacts for corrosion or other reasons the camera is not powering up.
Be sure to remove the SD memory card before replacing the battery contacts.
필요한 것
Turn to the bottom of the camera to access the battery department door.
Push the battery lock up to open.
Slide the batteries out of the camera.
Place the camera on a flat surface so that the lens is facing up.
Use the Phillips #00 precision screwdriver to remove the innermost 4 mm Phillips head screw. Remove the door from the camera.
Place the door on a flat surface with the battery contact facing up. Remove the two 4 mm Phillips head screws.
Slide the battery contact from the door.
Carefully lift and turn over the LCD ccreen to see the motherboard.
Carefully disconnect the LCD screen ribbon cable away from its ZIF connector with your thumb and index finger. Make sure to have your thumb and index finger cover as much of the ribbon's width and as close to the ZIF connector as possible without touching the motherboard while pulling the ribbon out.
Use the soldering iron to separate the black and red power wires from the motherboard.
Use the plastic opening tool to separate the button circuit board from the shutter button and the settings dial housing unit.
Carefully disconnect the ribbon cable that is attached to the user buttons circuit board away from the ZIF connector that is attached to the motherboard.
Remove the user button circuit board.
다른 한 분이 해당 안내서를 완성하였습니다.
