소개
If you need to to replace you the lens of your camera, we recommend that you use this guide.
Carefully lift and turnover the LCD Screen so that you are able to see the motherboard.
Carefully disconnect the LCD Screen ribbon cable away from its ZIF connector with your thumb and index finger. You must make sure to have your thumb and index finger cover as much of the ribbon's width and as close to the ZIF connector as possible without touching the motherboard while pulling the ribbon out.
Use the plastic opening tool to begin separating the button circuit board from the shutter button and settings dial housing unit.
Carefully disconnect the ribbon cable that is attached to the user buttons circuit board away from the ZIF connector that is attached to the motherboard.
Remove the user button circuit board.
Use the screwdriver to remove the three 3 mm Phillips screws from the lens metal frame.
Use the screwdriver to remove the two 3.5 mm Phillips screws from the lens metal frame.
Pull out the AV DC IN port out.
Turn the camera over so the bottom is exposed to remove the 3 mm Phillips head screw to disassemble the battery housing unit from the camera.
다른 2명이 해당 안내서를 완성하였습니다.
