주요 콘텐츠로 건너뛰기
Canon Powershot A95 Flash Unit Replacement
필요한 것
  1. Canon Powershot A95 Flash Unit Replacement, Flash Unit: 1 단계, 이미지 1/3 Canon Powershot A95 Flash Unit Replacement, Flash Unit: 1 단계, 이미지 2/3 Canon Powershot A95 Flash Unit Replacement, Flash Unit: 1 단계, 이미지 3/3
    • Have a small Phillips-head screwdriver and extender, an opening tool, and a soldering iron to complete the following steps.
    • Keep the screws organized and separated as you remove them.
  2. Canon Powershot A95 Flash Unit Replacement: 2 단계, 이미지 1/1
    • Locate the memory card slot on the far right with the screen facing toward you.
    • Remove the memory card.
  3. Canon Powershot A95 Flash Unit Replacement: 3 단계, 이미지 1/2 Canon Powershot A95 Flash Unit Replacement: 3 단계, 이미지 2/2
    • With the screen facing toward you, the battery slot can be found under the right side of the camera.
    • Remove all batteries and leave the slot open.
  4. Canon Powershot A95 Flash Unit Replacement: 4 단계, 이미지 1/3 Canon Powershot A95 Flash Unit Replacement: 4 단계, 이미지 2/3 Canon Powershot A95 Flash Unit Replacement: 4 단계, 이미지 3/3
    • There are two screws to the right of the battery slot.
    • Take the #00 Phillips-head screwdriver and remove the two screws.
  5. Canon Powershot A95 Flash Unit Replacement: 5 단계, 이미지 1/2 Canon Powershot A95 Flash Unit Replacement: 5 단계, 이미지 2/2
    • Inside the battery slot, there are another 3 screws located at the very bottom of each slot.
    • To reach these screws and remove them, attach the screwdriver extender to the #00 Phillips-head screwdriver.
  6. Canon Powershot A95 Flash Unit Replacement: 6 단계, 이미지 1/2 Canon Powershot A95 Flash Unit Replacement: 6 단계, 이미지 2/2
    • At the base of the battery flap, there are 2 screws located next to the hinges of the opening.
    • Remove both screws.
  7. Canon Powershot A95 Flash Unit Replacement: 7 단계, 이미지 1/2 Canon Powershot A95 Flash Unit Replacement: 7 단계, 이미지 2/2
    • Using the pry tool, pry the top of the camera open.
    • Be sure not to apply too much force and damage the wires under the lid.
    • The top should dangle loosely from the camera and not be fully detached.
  8. Canon Powershot A95 Flash Unit Replacement: 8 단계, 이미지 1/2 Canon Powershot A95 Flash Unit Replacement: 8 단계, 이미지 2/2
    • Once the top is loose, locate the 2 screws near the AV outlet.
    • The removal of the 2 screws will allow you to remove the plastic AV covering.
    • Once the AV cover is removed, there will be 1 more screw left to remove.
  9. Canon Powershot A95 Flash Unit Replacement: 9 단계, 이미지 1/2 Canon Powershot A95 Flash Unit Replacement: 9 단계, 이미지 2/2
    • Using the pry tool, gently remove the front cover of the camera in order to expose the flash and the lens.
  10. Canon Powershot A95 Flash Unit Replacement: 10 단계, 이미지 1/2 Canon Powershot A95 Flash Unit Replacement: 10 단계, 이미지 2/2
    • Locate the black film under the flash unit and remove the screw holding it in place.
    • Once the screw is removed, gently wiggle the flash out of place without damaging any internal parts.
  11. Canon Powershot A95 Flash Unit Replacement: 11 단계, 이미지 1/2 Canon Powershot A95 Flash Unit Replacement: 11 단계, 이미지 2/2
    • There will be a second black film which is covering the flash wires.
    • Remove the film to reveal the wires.
  12. Canon Powershot A95 Flash Unit Replacement: 12 단계, 이미지 1/1
    • Once the second film is removed and has revealed the flash wires, proceed to unsolder the necessary wires in order to detach the flash.
    • Take the new flash and solder it where the old one was removed.
결론
To reassemble, follow the disassemble steps in reverse order.
Amber
회원 가입일: 02/12/13
3 평판
안내서 1개 작성함
Ohio State, Team 1-4, Buehl Spring 2013 Ohio State, Team 1-4, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G4
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 831
