주요 콘텐츠로 건너뛰기
Canon Powershot ELPH 100 HS Battery Replacement
  1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: 1 단계, 이미지 1/3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: 1 단계, 이미지 2/3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Battery Replacement: 2 단계, 이미지 1/2 Canon Powershot ELPH 100 HS Battery Replacement: 2 단계, 이미지 2/2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lillia
회원 가입일: 03/17/15
255 평판
안내서 2개 작성하였습니다
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 회원
MTU-LAUER-S15S1G10
2 회원들
안내서 5개 작성하였습니다
댓글 2개
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
S Silvia - 답글
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
Sarah Westberg -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 54
전체 시간: 1,789
