주요 콘텐츠로 건너뛰기
Canon Powershot ELPH 100 HS Memory Card Replacement
  1. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: 1 단계, 이미지 1/3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: 1 단계, 이미지 2/3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Memory Card Replacement: 2 단계, 이미지 1/2 Canon Powershot ELPH 100 HS Memory Card Replacement: 2 단계, 이미지 2/2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: 3 단계, 이미지 1/3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: 3 단계, 이미지 2/3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: 3 단계, 이미지 3/3
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
결론
Lillia
회원 가입일: 03/17/15
255 평판
안내서 2개 작성하였습니다
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015 회원
MTU-LAUER-S15S1G10
2 회원들
안내서 5개 작성하였습니다
댓글 한 개
my internal card reader hardware is not functional
can i replace it somehow
s l - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 31
전체 시간: 966
