주요 콘텐츠로 건너뛰기
Canon Powershot Pro1 Lens Replacement
필요한 것
  1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: 1 단계, 이미지 2개 중 1개 Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: 1 단계, 이미지 2개 중 2개
    • Have the lens of the camera facing upwards.
    • Find the red plastic ring.
    • Look for two small opening above the red plastic ring.
    • Reference to the left of the picture and you will see the orange square.
  2. Canon Powershot Pro1 Lens Replacement: 2 단계, 이미지 3개 중 1개 Canon Powershot Pro1 Lens Replacement: 2 단계, 이미지 3개 중 2개 Canon Powershot Pro1 Lens Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the plastic ring that has a red strip.
    • Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
  3. Canon Powershot Pro1 Lens Replacement: 3 단계, 이미지 3개 중 1개 Canon Powershot Pro1 Lens Replacement: 3 단계, 이미지 3개 중 2개 Canon Powershot Pro1 Lens Replacement: 3 단계, 이미지 3개 중 3개
    • Place the camera on its back with the lens facing upwards as shown in the image
    • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
    • Remove the screw by turning the Philip driver counterclockwise.
    • By removing the screw, you will be able to remove the cover lens.
  4. Canon Powershot Pro1 Lens Replacement: 4 단계, 이미지 1개 중 1개
    • Use the nylon spudger to remove the ring holding the lens in place.
    • Pull gently until the lens ring snaps off.
  5. Canon Powershot Pro1 Lens Replacement: 5 단계, 이미지 1개 중 1개
    • Refer to the left-hand pictere to see what the len's ring looks like.
  6. Canon Powershot Pro1 Lens Replacement: 6 단계, 이미지 3개 중 1개 Canon Powershot Pro1 Lens Replacement: 6 단계, 이미지 3개 중 2개 Canon Powershot Pro1 Lens Replacement: 6 단계, 이미지 3개 중 3개
    • Take out the lens once the plastic ring is removed
    • Hold the outer layer of the lens to not create smudges on it.
    • Replace the lens and follow the instruction in reversed order to reassemble the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Seana Meegan
회원 가입일: 09/06/19
677 평판
안내서 5개를 작성함
댓글 한 개
Hi, can you do a guide on how to repair the diaphragm?
OTVaL - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 35
전체 시간: 2,939
