주요 콘텐츠로 건너뛰기
Canon Powershot Pro1 Motherboard Replacement
필요한 것
  1. Canon Powershot Pro1 Motherboard  Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Motherboard  Replacement: 2 단계, 이미지 1개 중 1개
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Motherboard  Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Motherboard  Replacement: 4 단계, 이미지 1개 중 1개
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Motherboard  Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
    • Open the screen to access the underside of the camera.
  6. Canon Powershot Pro1 Motherboard  Replacement: 6 단계, 이미지 3개 중 1개 Canon Powershot Pro1 Motherboard  Replacement: 6 단계, 이미지 3개 중 2개 Canon Powershot Pro1 Motherboard  Replacement: 6 단계, 이미지 3개 중 3개
    • Using the Phillips #000 screwdriver:
    • Remove two 1.00 mm screws under the viewfinder.
    • Remove one screw in the battery compartment.
    • Remove five screws on the bottom of the camera.
    • Remove one screw on the left side of the camera (opposite the battery compartment).
  7. Canon Powershot Pro1 Motherboard  Replacement: 7 단계, 이미지 3개 중 1개 Canon Powershot Pro1 Motherboard  Replacement: 7 단계, 이미지 3개 중 2개 Canon Powershot Pro1 Motherboard  Replacement: 7 단계, 이미지 3개 중 3개
    • Completely detach the cover from the motherboard.
    • Lift the inside cover to reveal the motherboard.
    • Detach the bottom right ribbon cable from the motherboard.
  8. Canon Powershot Pro1 Motherboard  Replacement: 8 단계, 이미지 2개 중 1개 Canon Powershot Pro1 Motherboard  Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Lift up the gold insulation cover to reveal the motherboard.
    • Use tweezers and an iFixit opening tool, detach any wire connectors and ribbon cables from the motherboard.
  9. Canon Powershot Pro1 Motherboard  Replacement: 9 단계, 이미지 3개 중 1개 Canon Powershot Pro1 Motherboard  Replacement: 9 단계, 이미지 3개 중 2개 Canon Powershot Pro1 Motherboard  Replacement: 9 단계, 이미지 3개 중 3개
    • Once detached from all connectors and ribbon cables, remove the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Seana Meegan
회원 가입일: 09/06/19
677 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 23
전체 시간: 1,200
