주요 콘텐츠로 건너뛰기
Canon Powershot S110 Option Dial Replacement
필요한 것
  1. Canon Powershot S110 Option Dial Replacement, Option Dial: 1 단계, 이미지 1/2 Canon Powershot S110 Option Dial Replacement, Option Dial: 1 단계, 이미지 2/2
    • Remove the battery by sliding open the battery cover on the bottom of the camera.
    • The battery must be removed to avoid shorting out any part of the camera.
  2. Canon Powershot S110 Option Dial Replacement: 2 단계, 이미지 1/3 Canon Powershot S110 Option Dial Replacement: 2 단계, 이미지 2/3 Canon Powershot S110 Option Dial Replacement: 2 단계, 이미지 3/3
    • Remove the six screws by using a small Phillips head screwdriver.
    • Remove the two screws on the side of the camera on either side of the HDMI input panel.
    • Remove the two screws on the opposite side of the camera.
    • Remove the two screws on the bottom of the camera located on either side of the tripod mounting hole.
  3. Canon Powershot S110 Option Dial Replacement: 3 단계, 이미지 1/1
    • Using an opening tool, carefully remove the outermost cover of the camera from its holders around the edges.
    • Once all of the clips around the plastic cover are released, the cover will lift off.
  4. Canon Powershot S110 Option Dial Replacement: 4 단계, 이미지 1/2 Canon Powershot S110 Option Dial Replacement: 4 단계, 이미지 2/2
    • Remove the two screws holding the top plastic bracket in place by using a Phillips head screwdriver.
    • Remove the screw holding down the lens cover.
    • Remove the screw located near the option dial next to the USB connections.
  5. Canon Powershot S110 Option Dial Replacement: 5 단계, 이미지 1/1
    • Carefully lift the top panel of the camera by using a prying tool.
  6. Canon Powershot S110 Option Dial Replacement: 6 단계, 이미지 1/1
    • Remove the screw at the center of the option dial by using a Phillips head screwdriver.
  7. Canon Powershot S110 Option Dial Replacement: 7 단계, 이미지 1/2 Canon Powershot S110 Option Dial Replacement: 7 단계, 이미지 2/2
    • Remove the underlying component that was attached to the now-removed screw by using a prying tool.
    • Remove the dial on the opposite side of the part using a prying tool.
결론
다른 2명이 해당 안내서를 완성하였습니다.
akac92
회원 가입일: 07/14/15
298 평판
안내서 2개 작성하였습니다
UW Tacoma, Team 1-2, Liner SU 2015 UW Tacoma, Team 1-2, Liner SU 2015 회원
UWT-LINER-SU15S1G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 1,143
