주요 콘텐츠로 건너뛰기
Canon Powershot S200 Motherboard Replacement
필요한 것
  1. Canon Powershot S200 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Canon Powershot S200 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: 2 단계, 이미지 1/2 Canon Powershot S200 Motherboard Replacement: 2 단계, 이미지 2/2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: 5 단계, 이미지 1/1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: 9 단계, 이미지 1/1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: 10 단계, 이미지 1/2 Canon Powershot S200 Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: 11 단계, 이미지 1/2 Canon Powershot S200 Motherboard Replacement: 11 단계, 이미지 2/2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: 12 단계, 이미지 1/1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Motherboard Replacement: 15 단계, 이미지 1/2 Canon Powershot S200 Motherboard Replacement: 15 단계, 이미지 2/2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: 16 단계, 이미지 1/1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: 17 단계, 이미지 1/1
    • Remove the motherboard from the main frame of the camera body.
결론
Orlando Zuniga
회원 가입일: 04/14/11
11 평판
안내서 1개 작성함
Cal Poly, Team 20-70, Walters Spring 2011 Cal Poly, Team 20-70, Walters Spring 2011 회원
CPSU-WALTERS-S11S20G70
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,873
