이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the camera to the side that has the attachment for the wrist strap.
Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Remove the plastic subsection by prying it with your fingers.
The wrist strap attachment behind the subsection will come loose and may fall out.
Turn the camera over to the side opposite of the wrist strap.
Remove the two silver 3.4 mm screws with a #00 Phillips screwdriver.
Flip the camera upside down.
Remove the following screws with a #00 Phillips screwdriver.
One black 3.4 mm Phillips screw.
One silver 3.4 mm Phillips screw.
Place the camera on the side opposite of the wrist strap handle.
Then begin to pry the casing apart with both hands by applying pressure to the top and bottom of the camera.
Remove the small metal plate underneath the plastic covering and set aside. (It should be loosely attached)
다른 5명이 해당 안내서를 완성하였습니다.
