주요 콘텐츠로 건너뛰기
Canon Powershot SD790 IS LCD Screen Replacement
필요한 것
  1. Canon Powershot SD790 IS LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 Canon Powershot SD790 IS LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 Canon Powershot SD790 IS LCD Screen Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
    • Remove the two screws from the left side of the camera using a Phillips #00 screwdriver.
    • Remove the two screws from the right side of the camera using a Phillips #00 screwdriver.
    • Remove the two screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Canon Powershot SD790 IS LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Canon Powershot SD790 IS LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Using your fingers, manually open the USB cover, labeled as “A/V OUT DIGITAL.”
    • Gently pull the tab of the side cover, completely detaching the cover from the camera.
  3. Canon Powershot SD790 IS LCD Screen Replacement: 3 단계, 이미지 3개 중 1개 Canon Powershot SD790 IS LCD Screen Replacement: 3 단계, 이미지 3개 중 2개 Canon Powershot SD790 IS LCD Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Gently grab the sides of the camera and pry off the screen cover using your fingers.
    • If necessary, use a spudger.
    • Once the screen cover is removed, the front cover and side plate will slide off.
  4. Canon Powershot SD790 IS LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Canon Powershot SD790 IS LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the screw located below the button release panel.
  5. Canon Powershot SD790 IS LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, gently slide the LCD cable, horizontally from its white plug towards the camera screen.
  6. Canon Powershot SD790 IS LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Caution: Do not completely remove the button release panel from the camera. The black and red cables will keep the panel attached to the camera. Allow the panel to hang out of the way as you complete the remaining steps.
    • Using your fingers, open the USB port cover (labeled as “A/V OUT DIGITAL” on the camera).
    • Using your fingers, remove the button release panel located on the top of the camera and allow room for it to hang out of the way.
  7. Canon Powershot SD790 IS LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Canon Powershot SD790 IS LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Using the spudger, flip the clip in an upward motion. The clip should remain attached to camera, not removed completely.
  8. Canon Powershot SD790 IS LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Using tweezers, gently slide the orange, translucent LCD ribbon from its dark gray plug horizontally towards the screen.
    • Remove the screen from the camera, and attach the new screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
14다른 기여자 명과 함께
Gabriela
회원 가입일: 01/11/11
150 평판
안내서 1개를 작성함
Cal Poly, Team 4-33, Regan Winter 2011 Cal Poly, Team 4-33, Regan Winter 2011 회원
CPSU-REGAN-W11S4G33
4 회원들
안내서 5개를 작성함
1가이드 댓글
do I just put everyhting back together in the backwards order of how I took it off?
zion saez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 24
전체 시간: 4,287
