주요 콘텐츠로 건너뛰기
Canon Powershot SD880 Front Cover Replacement
필요한 것
  1. Canon Powershot SD880 Front Cover Replacement, Back Cover: 1 단계, 이미지 1/3 Canon Powershot SD880 Front Cover Replacement, Back Cover: 1 단계, 이미지 2/3 Canon Powershot SD880 Front Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 Front Cover Replacement, Front Cover: 2 단계, 이미지 1/3 Canon Powershot SD880 Front Cover Replacement, Front Cover: 2 단계, 이미지 2/3 Canon Powershot SD880 Front Cover Replacement, Front Cover: 2 단계, 이미지 3/3
    • Remove the 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 4.1 mm screw from the menu button side of the camera using a Phillips #00 screwdriver.
    • The two screws on the other side of the camera were already removed when the back cover was taken off.
결론
Robert Manno
회원 가입일: 01/05/11
432 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 회원
CPSU-FORTE-W11S13G3
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 2,817
