주요 콘텐츠로 건너뛰기
Canon Powershot SD880 LCD Display Replacement
필요한 것
  1. Canon Powershot SD880 LCD Display Replacement, Back Cover: 1 단계, 이미지 1/3 Canon Powershot SD880 LCD Display Replacement, Back Cover: 1 단계, 이미지 2/3 Canon Powershot SD880 LCD Display Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
    • Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
    • One screw will be located under the rubber USB flap.
    • Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
    • Slowly pull the back cover off of the camera.
  2. Canon Powershot SD880 LCD Display Replacement, LCD Display: 2 단계, 이미지 1/3 Canon Powershot SD880 LCD Display Replacement, LCD Display: 2 단계, 이미지 2/3 Canon Powershot SD880 LCD Display Replacement, LCD Display: 2 단계, 이미지 3/3
    • Remove the two 2.9 mm screws at the top-right corner and bottom-left corner of the LCD screen using a Phillips #0 screwdriver.
    • Disconnect the ribbons that connect the screen to the camera.
    • Lift the screen off.
결론
Ben Tupas
회원 가입일: 01/13/11
317 평판
안내서 3개 작성하였습니다
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011 회원
CPSU-FORTE-W11S13G3
5 회원들
안내서 8개 작성하였습니다
댓글 한 개
Hm. "Disconnect the ribbons" resulted in a torn ribbon, and so a dead camera, I think. This also doesn't say how to take the LCD screen out of its frame. Alas.
Maelduin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 2,338
