이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Remove the two 2.4 mm screws on the side of the camera that are next to the LCD screen using a Phillips #00 screwdriver.
Remove the two 4.1 mm screws on the other side using a Phillips #00 screwdriver.
Remove the single 2.6 mm screw from the bottom of the camera using a Phillips #00 screwdriver.
Slowly pull the back cover off of the camera.
Unplug the green and white plugs connecting the top panel to the top of the logic board.
Dislodge the tab above the lens.
Dislodge the back tab.
