주요 콘텐츠로 건너뛰기
Canon Powershot SX10 IS LCD Screen Replacement
필요한 것
  1. Canon Powershot SX10 IS LCD Screen Replacement, Lithium Ion Battery: 1 단계, 이미지 1/1
    • Open the door. Release the catch by sliding it towards the side of the camera.
    • Then slide the door towards the front of the camera.
  2. Canon Powershot SX10 IS LCD Screen Replacement: 2 단계, 이미지 1/3 Canon Powershot SX10 IS LCD Screen Replacement: 2 단계, 이미지 2/3 Canon Powershot SX10 IS LCD Screen Replacement: 2 단계, 이미지 3/3
    • Remove AA batteries.
    • Using a fingernail or iFixit opening tools to pry up the battery cradle.
    • Remove CR1220 battery from the cradle.
  3. Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: 3 단계, 이미지 1/2 Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: 3 단계, 이미지 2/2
    • Remove all four screws on the corners of the screen cover.
    • Gently pry open the cover with a fingernail or iFixit opening tool.
  4. Canon Powershot SX10 IS LCD Screen Replacement: 4 단계, 이미지 1/3 Canon Powershot SX10 IS LCD Screen Replacement: 4 단계, 이미지 2/3 Canon Powershot SX10 IS LCD Screen Replacement: 4 단계, 이미지 3/3
    • Remove two screws holding on the cover plate on the pivot.
    • Remove the cover plate using an iFixit opening tool.
    • You may need to loosen the bottom first, then pry on the top of the cover plate.
    • Remove the two screws on top of the swivel arm. These two screws will be separated by the pivot point.
  5. Canon Powershot SX10 IS LCD Screen Replacement: 5 단계, 이미지 1/3 Canon Powershot SX10 IS LCD Screen Replacement: 5 단계, 이미지 2/3 Canon Powershot SX10 IS LCD Screen Replacement: 5 단계, 이미지 3/3
    • Remove grounding wire, then continue to remove the screws holding the screen and front cover plate on.
    • The screen and plate will drop after removing the last screw.
  6. Canon Powershot SX10 IS LCD Screen Replacement: 6 단계, 이미지 1/2 Canon Powershot SX10 IS LCD Screen Replacement: 6 단계, 이미지 2/2
    • Unlatch the ribbon strip and power wires from the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
garrett knox
회원 가입일: 04/05/19
333 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 33
전체 시간: 1,213
