주요 콘텐츠로 건너뛰기
Canon Powershot SX10 IS Tripod Screw Mount Replacement
필요한 것
  1. Canon Powershot SX10 IS Tripod Screw Mount Replacement, Lithium Ion Battery: 1 단계, 이미지 1/1
    • Open the door. Release the catch by sliding it towards the side of the camera.
    • Then slide the door towards the front of the camera.
  2. Canon Powershot SX10 IS Tripod Screw Mount Replacement: 2 단계, 이미지 1/3 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 2 단계, 이미지 2/3 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 2 단계, 이미지 3/3
    • Remove AA batteries.
    • Using a fingernail or iFixit opening tools to pry up the battery cradle.
    • Remove CR1220 battery from the cradle.
  3. Canon Powershot SX10 IS Tripod Screw Mount Replacement, Rear and Front Casing: 3 단계, 이미지 1/1
    • Remove two PH 00 screws on each side of the eyepiece.
  4. Canon Powershot SX10 IS Tripod Screw Mount Replacement: 4 단계, 이미지 1/1
    • Remove the two PH 00 screws on the right panel of the camera.
  5. Canon Powershot SX10 IS Tripod Screw Mount Replacement: 5 단계, 이미지 1/1
    • Remove five PH 00 screws on the bottom.
  6. Canon Powershot SX10 IS Tripod Screw Mount Replacement: 6 단계, 이미지 1/3 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 6 단계, 이미지 2/3 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 6 단계, 이미지 3/3
    • Use the iFixit opening tool to free the back casing from the rest of the camera body.
    • Be careful because there is a ribbon cable that attaches the back casing to the motherboard.
    • Gently lift up on the black latch holding the ribbon cable in place and slide the ribbon out.
  7. Canon Powershot SX10 IS Tripod Screw Mount Replacement: 7 단계, 이미지 1/2 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 7 단계, 이미지 2/2
    • Remove three screws on the left side of the camera.
    • Slide the left side casing up and off of the camera body.
  8. Canon Powershot SX10 IS Tripod Screw Mount Replacement: 8 단계, 이미지 1/1
    • Remove two screws holding the front casing to the body.
  9. Canon Powershot SX10 IS Tripod Screw Mount Replacement: 9 단계, 이미지 1/3 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 9 단계, 이미지 2/3 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 9 단계, 이미지 3/3
    • Remove two cables connected to the motherboard.
    • Use thin tweezers to push down on the clear piece and slide it out. At this point half of the clear piece should be free.
    • Remove one screw that is holding down the middle of the clear piece to the body of the camera. The whole structure with wires will swing out.
  10. Canon Powershot SX10 IS Tripod Screw Mount Replacement: 10 단계, 이미지 1/3 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 10 단계, 이미지 2/3 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 10 단계, 이미지 3/3
    • Using the iFixit opening tool, gently pry along the top edge of the front casing.
    • Move to the right side of the camera and gently pry at the top and bottom areas of this part of the casing. The front casing will come free once it has been pried here.
    • The front casing will be able to slide away from the body of the camera.
  11. Canon Powershot SX10 IS Tripod Screw Mount Replacement, Tripod Screw Mount: 11 단계, 이미지 1/2 Canon Powershot SX10 IS Tripod Screw Mount Replacement, Tripod Screw Mount: 11 단계, 이미지 2/2
    • Remove one screw that holds both a black cable and part of the tripod mount.
    • The silver bracket and black cable will pop right off.
  12. Canon Powershot SX10 IS Tripod Screw Mount Replacement: 12 단계, 이미지 1/2 Canon Powershot SX10 IS Tripod Screw Mount Replacement: 12 단계, 이미지 2/2
    • Remove the four screws remaining that hold the tripod screw mount into the body of the camera.
    • Using your fingers, remove the tripod screw mount from the body of the camera.
결론
Sant Strassheim
회원 가입일: 04/05/19
169 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 512
