주요 콘텐츠로 건너뛰기
Canon Powershot SX30 IS LCD Panel Front Cover Replacement
필요한 것
  1. Canon Powershot SX30 IS LCD Panel Front Cover Replacement, LCD Panel Rear Cover: 1 단계, 이미지 1/1
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 2 단계, 이미지 1/2 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 2 단계, 이미지 2/2
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 3 단계, 이미지 1/3 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 3 단계, 이미지 2/3 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 3 단계, 이미지 3/3
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 4 단계, 이미지 1/2 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 4 단계, 이미지 2/2
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 5 단계, 이미지 1/1
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
  6. Canon Powershot SX30 IS LCD Panel Front Cover Replacement, LCD Panel Front Cover: 6 단계, 이미지 1/1
    • Unscrew the 2mm screw on the outer edge of the panel
  7. Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 7 단계, 이미지 1/2 Canon Powershot SX30 IS LCD Panel Front Cover Replacement: 7 단계, 이미지 2/2
    • Unscrew the 3mm screw on the inner edge of the panel. This is easily done by rotating the screen to be perpendicular to the body of the camera, but be careful not to damage the wires or the circuit board.
    • The panel will fall right off
결론
Ellis DeVoe
회원 가입일: 04/14/15
580 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-12, Maness Spring 2015 Cal Poly, Team 5-12, Maness Spring 2015 회원
CPSU-MANESS-S15S5G12
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 567
