주요 콘텐츠로 건너뛰기
Canon Powershot SX30 IS LCD Panel Rear Cover Replacement
필요한 것
  1. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement, LCD Panel Rear Cover: 1 단계, 이미지 1/1
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 2 단계, 이미지 1/2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 2 단계, 이미지 2/2
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 3 단계, 이미지 1/3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 3 단계, 이미지 2/3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 3 단계, 이미지 3/3
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 4 단계, 이미지 1/2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 4 단계, 이미지 2/2
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: 5 단계, 이미지 1/1
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
결론
Ellis DeVoe
회원 가입일: 04/14/15
580 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-12, Maness Spring 2015 Cal Poly, Team 5-12, Maness Spring 2015 회원
CPSU-MANESS-S15S5G12
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 283
