주요 콘텐츠로 건너뛰기
Canon Powershot SX500 IS Control Dial Replacement
필요한 것
  1. Canon Powershot SX500 IS Control Dial Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Control Dial Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Control Dial Replacement: 3 단계, 이미지 1개 중 1개
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Control Dial Replacement, Back Cover: 4 단계, 이미지 3개 중 1개 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: 4 단계, 이미지 3개 중 2개 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: 4 단계, 이미지 3개 중 3개
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Control Dial Replacement: 5 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Control Dial Replacement: 6 단계, 이미지 1개 중 1개
  7. Canon Powershot SX500 IS Control Dial Replacement: 7 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Control Dial Replacement: 8 단계, 이미지 2개 중 1개 Canon Powershot SX500 IS Control Dial Replacement: 8 단계, 이미지 2개 중 2개
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Control Dial Replacement, Control Dial: 9 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS Control Dial Replacement: 10 단계, 이미지 1개 중 1개
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS Control Dial Replacement: 11 단계, 이미지 1개 중 1개
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS Control Dial Replacement: 12 단계, 이미지 1개 중 1개
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Shelby Spiering
회원 가입일: 04/07/15
252 평판
안내서 1개를 작성함
댓글 한 개
Gracias gracias gracias
edgarlugo20111917 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 480
