주요 콘텐츠로 건너뛰기
소개
User needs PH00 screwdriver, spudger, and plastic pry tool.
  1. Rotate the camera to expose the underside of the camera.
    • Rotate the camera to expose the underside of the camera.
  2. Slide the rounded rectangle tab to the left to release the battery cover.
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Push the small orange tab forward to release the battery      (Battery is ready for removal).
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen. Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen. Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  7. Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Using the plastic pry tool, remove the back cover from camera. Using the plastic pry tool, remove the back cover from camera.
    • Using the plastic pry tool, remove the back cover from camera.
  9. Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Using the Phiillips 00 screwdriver, remove the 4mm screw to the  right of the control dial.
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Using the spudger, lift the control dial to the right of  the LCD screen.
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Shelby Spiering
회원 가입일: 2015년 04월 07일
222 평판
안내서 1개 작성함
댓글 한 개
Gracias gracias gracias
edgarlugo20111917 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 359
