주요 콘텐츠로 건너뛰기
Canon Powershot SX500 IS Lens Replacement
필요한 것
  1. Canon Powershot SX500 IS Lens Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Lens Replacement: 3 단계, 이미지 1개 중 1개
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Lens Replacement, Back Cover: 4 단계, 이미지 3개 중 1개 Canon Powershot SX500 IS Lens Replacement, Back Cover: 4 단계, 이미지 3개 중 2개 Canon Powershot SX500 IS Lens Replacement, Back Cover: 4 단계, 이미지 3개 중 3개
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Lens Replacement: 5 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Lens Replacement: 6 단계, 이미지 1개 중 1개
  7. Canon Powershot SX500 IS Lens Replacement: 7 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Lens Replacement: 8 단계, 이미지 2개 중 1개 Canon Powershot SX500 IS Lens Replacement: 8 단계, 이미지 2개 중 2개
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Lens Replacement, LCD Screen: 9 단계, 이미지 1개 중 1개
    • Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
  10. Canon Powershot SX500 IS Lens Replacement, Lens: 10 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver remove the seven 6mm screws from the housing plate of the LCD screen.
  11. Canon Powershot SX500 IS Lens Replacement: 11 단계, 이미지 1개 중 1개
    • Using the Phillips 00 screwdriver, remove the 4mm mounting screw from underneath the flash.
  12. Canon Powershot SX500 IS Lens Replacement: 12 단계, 이미지 1개 중 1개
    • Using the spudger, lift the flash unit away from the metal housing (Flash is lifted to allow more room for metal housing).
  13. Canon Powershot SX500 IS Lens Replacement: 13 단계, 이미지 1개 중 1개
    • Using the spudger, remove the metal housing (Metal housing is removed from camera).
  14. Canon Powershot SX500 IS Lens Replacement: 14 단계, 이미지 2개 중 1개 Canon Powershot SX500 IS Lens Replacement: 14 단계, 이미지 2개 중 2개
    • Using the spudger, lift the tab on the ZIF connector and remove both orange ribbons connected to the green motherboard (Motherboard is lifted from camera).
  15. Canon Powershot SX500 IS Lens Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the lens from the lens shaft (Lens is removed from camera).
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jody Wilkerson
회원 가입일: 04/07/15
565 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 3,927
