주요 콘텐츠로 건너뛰기
Canon SX40 HS Camera Battery Door Contact Replacement
필요한 것
  1. Canon SX40 HS Camera Battery Door Contact Replacement, Battery Door Contact: 1 단계, 이미지 1/1
    • Orient the camera so that the bottom of the camera is facing up and open the battery compartment.
  2. Canon SX40 HS Camera Battery Door Contact Replacement: 2 단계, 이미지 1/1
    • Remove the two circled 2mm screws with a Phillips #00 screwdriver.
  3. Canon SX40 HS Camera Battery Door Contact Replacement: 3 단계, 이미지 1/1
    • Slide the metal battery contact away from the battery compartment cover.
  4. Canon SX40 HS Camera Battery Door Contact Replacement: 4 단계, 이미지 1/1
    • Remove the battery compartment cover from the metal bracket.
  5. Canon SX40 HS Camera Battery Door Contact Replacement: 5 단계, 이미지 1/1
    • Replace either the internal metal battery contact or external battery compartment cover.
결론
John Bui
회원 가입일: 03/26/15
352 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-7, Cichon Spring 2015 UMass Dartmouth, Team 7-7, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G7
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 834
