주요 콘텐츠로 건너뛰기
Canon SX40 HS camera Flash Cover Replacement
필요한 것
  1. Canon SX40 HS camera Flash Cover Replacement, Flash Cover: 1 단계, 이미지 1/2 Canon SX40 HS camera Flash Cover Replacement, Flash Cover: 1 단계, 이미지 2/2
    • Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
    • Repeat to remove the 4 mm black screw located on the right side.
  2. Canon SX40 HS camera Flash Cover Replacement: 2 단계, 이미지 1/1
    • Remove the plastic cover using the iFixIt Plastic Opening Tool.
    • The plastic cover can only be removed in the down position.
  3. Canon SX40 HS camera Flash Cover Replacement: 3 단계, 이미지 1/2 Canon SX40 HS camera Flash Cover Replacement: 3 단계, 이미지 2/2
    • After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
    • Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera Flash Cover Replacement: 4 단계, 이미지 1/1
    • Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
결론
To reassemble your device, follow Steps 1-4 in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
John Bui
회원 가입일: 03/26/15
352 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 7-7, Cichon Spring 2015 UMass Dartmouth, Team 7-7, Cichon Spring 2015 회원
UMASSD-CICHON-S15S7G7
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 12
전체 시간: 801
