주요 콘텐츠로 건너뛰기
Canon Selphy CP1200 Battery Leads Replacement
필요한 것
  1. Canon Selphy CP1200 Battery Leads Replacement, LCD/Buttons: 1 단계, 이미지 1개 중 1개
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 Battery Leads Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 Battery Leads Replacement: 3 단계, 이미지 1개 중 1개
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 Battery Leads Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
  5. Canon Selphy CP1200 Battery Leads Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Detach the fan cable from the motherboard.
  6. Canon Selphy CP1200 Battery Leads Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
  7. Canon Selphy CP1200 Battery Leads Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the three 3mm PH000 screws from the motherboard.
  8. Canon Selphy CP1200 Battery Leads Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the bundled cables leading to the printing mechanism.
  9. Canon Selphy CP1200 Battery Leads Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
  10. Canon Selphy CP1200 Battery Leads Replacement, Print Mechanism: 10 단계, 이미지 2개 중 1개 Canon Selphy CP1200 Battery Leads Replacement, Print Mechanism: 10 단계, 이미지 2개 중 2개
    • Open the side door and depress the ink cassette release.
    • Slide out and remove the ink cassette.
  11. Canon Selphy CP1200 Battery Leads Replacement: 11 단계, 이미지 1개 중 1개
    • Unscrew the three 3mm PH000 screws securing the metal plate to the printing mechanism.
  12. Canon Selphy CP1200 Battery Leads Replacement: 12 단계, 이미지 1개 중 1개
    • Lift out the print mechanism of the printer case.
  13. Canon Selphy CP1200 Battery Leads Replacement, Battery Leads: 13 단계, 이미지 2개 중 1개 Canon Selphy CP1200 Battery Leads Replacement, Battery Leads: 13 단계, 이미지 2개 중 2개
    • Lift out the back case plate.
    • Remove the battery leads by lifting it out of its niche in the case.
결론
작성자
2다른 기여자 명과 함께
W Sherer
회원 가입일: 01/16/19
647 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 850
