주요 콘텐츠로 건너뛰기
Canon Selphy CP1200 Motherboard Replacement
필요한 것
  1. Canon Selphy CP1200 Motherboard Replacement, LCD/Buttons: 1 단계, 이미지 1/1
    • Unscrew the four 6mm PH000 corner screws.
    • This will require a screwdriver with a long, narrow shaft.
  2. Canon Selphy CP1200 Motherboard Replacement: 2 단계, 이미지 1/1
    • Unscrew the three 4mm PH1 screws on the bottom of the printer.
  3. Canon Selphy CP1200 Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently pry open the top of the case from either the front or back.
    • A plastic opening tool may help.
    • Be careful in lifting the top assembly as it is attached to the motherboard at this point.
  4. Canon Selphy CP1200 Motherboard Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Keeping the top assembly elevated, detach the ribbon cables connecting the LCD and buttons to the motherboard from the motherboard.
    • Tweezers may be useful given the limited space between the top assembly and motherboard.
    • The top assembly, containing both the LCD and buttons, will now be completely free
  5. Canon Selphy CP1200 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Detach the fan cable from the motherboard.
  6. Canon Selphy CP1200 Motherboard Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Detach the ribbon cable leading to the DC in port and battery leads.
    • Tweezers may be useful.
  7. Canon Selphy CP1200 Motherboard Replacement: 7 단계, 이미지 1/1
    • Unscrew the three 3mm PH000 screws from the motherboard.
  8. Canon Selphy CP1200 Motherboard Replacement: 8 단계, 이미지 1/1
    • Disconnect the bundled cables leading to the printing mechanism.
  9. Canon Selphy CP1200 Motherboard Replacement: 9 단계, 이미지 1/1
    • Gently lift the motherboard and detach the ribbon cables leading to the print mechanism.
    • Tweezers may be useful due to the limited amount of space.
결론
W Sherer
회원 가입일: 01/16/19
635 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 26
전체 시간: 1,119
