주요 콘텐츠로 건너뛰기
Canon Sure Shot Z115 Caption Battery Replacement
필요한 것
  1. Canon Sure Shot Z115 Caption Battery Replacement, Battery: 1 단계, 이미지 1/1
    • This area is where the batteries are located, right corner of the camera.
  2. Canon Sure Shot Z115 Caption Battery Replacement: 2 단계, 이미지 1/2 Canon Sure Shot Z115 Caption Battery Replacement: 2 단계, 이미지 2/2
    • In this step, you will be opening the battery compartment. You can use a plastic opening tool, flathead screwdriver, or any other tool that is similar. On the device there is the word "open" with an arrow pointing in the direction to open the battery compartment.
  3. Canon Sure Shot Z115 Caption Battery Replacement: 3 단계, 이미지 1/1
    • In this step you will remove the batteries. If you tip the camera so it horizontal the batteries will simply fall out, which is much simpler than trying to pick them out of the compartment.
  4. Canon Sure Shot Z115 Caption Battery Replacement: 4 단계, 이미지 1/1
    • In this step you will add new 3V batteries. You need to make sure they are in the right charge (+,-) port which is labeled when you look inside the battery compartment with a positive and negative sign (positive side of the batter has a little lip negative side is completely flat).
  5. Canon Sure Shot Z115 Caption Battery Replacement: 5 단계, 이미지 1/2 Canon Sure Shot Z115 Caption Battery Replacement: 5 단계, 이미지 2/2
    • Now that the new batteries are in you can put the cover on top and screw back on the top cover. You have successfully changed the batteries.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Amanda McCullough
회원 가입일: 03/28/15
125 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-3, Shastany Spring 2015 UMass Dartmouth, Team 2-3, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S2G3
5 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 68
전체 시간: 5,787
