주요 콘텐츠로 건너뛰기
Canon Vixia HF R600 Casing Replacement
필요한 것
  1. Canon Vixia HF R600 Casing Replacement, Handstrap: 1 단계, 이미지 1/2 Canon Vixia HF R600 Casing Replacement, Handstrap: 1 단계, 이미지 2/2
    • Pull up the Velcro strap starting from the front of the camera and working your way towards the back.
    • If you are adjusting the hand-strap, tighten or loosen the Velcro strap accordingly and reattach it.
    • To remove the hand-strap, pull the Velcro strip through the leather pad.
  2. Canon Vixia HF R600 Casing Replacement: 2 단계, 이미지 1/2 Canon Vixia HF R600 Casing Replacement: 2 단계, 이미지 2/2
    • Remove the strap from the camera body.
  3. Canon Vixia HF R600 Casing Replacement, Battery: 3 단계, 이미지 1/2 Canon Vixia HF R600 Casing Replacement, Battery: 3 단계, 이미지 2/2
    • Press in the battery release tab located on the bottom of the camera.
    • Slide the battery out from the body.
  4. Canon Vixia HF R600 Casing Replacement, Casing: 4 단계, 이미지 1/2 Canon Vixia HF R600 Casing Replacement, Casing: 4 단계, 이미지 2/2
    • Start by removing the two 6mm Phillips #00 screws located on the right side of the camera.
    • Remove four more 6mm Phillips #00 screws found on the bottom of the camera.
  5. Canon Vixia HF R600 Casing Replacement: 5 단계, 이미지 1/2 Canon Vixia HF R600 Casing Replacement: 5 단계, 이미지 2/2
    • Open the display screen and remove the three 5mm Phillips #00 screws.
    • Look to the swivel point for the screen to find the last two 5mm Phillips #00 screws that must be removed.
  6. Canon Vixia HF R600 Casing Replacement: 6 단계, 이미지 1/2 Canon Vixia HF R600 Casing Replacement: 6 단계, 이미지 2/2
    • Gently pull the plastic casing away from the camera.
결론
Logan Coats
회원 가입일: 02/10/16
522 평판
안내서 4개 작성하였습니다
USF Tampa, Team 14-4, Lacy Spring 2016 USF Tampa, Team 14-4, Lacy Spring 2016 회원
USFT-LACY-S16S14G4
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 439
