주요 콘텐츠로 건너뛰기
Canon Vixia HF R62 Lens Replacement
필요한 것
  1. Canon Vixia HF R62 Lens Replacement, Outer Shell: 1 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement, Outer Shell: 1 단계, 이미지 2/2
    • Remove the strap by undoing the Velcro and pulling it through the thread points.
    • Remove the external battery pack by pressing down on the slide release and sliding it out.
  2. Canon Vixia HF R62 Lens Replacement: 2 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement: 2 단계, 이미지 2/2
    • Remove the three 5mm Phillips #000 screws on the bottom of the device.
  3. Canon Vixia HF R62 Lens Replacement: 3 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement: 3 단계, 이미지 2/2
    • On the side of the device, remove the following Phillips #000 screws:
    • One 3mm screw
    • One 5mm screw
  4. Canon Vixia HF R62 Lens Replacement: 4 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement: 4 단계, 이미지 2/2
    • Remove the panel opposite the display by pulling up perpendicular to the side.
  5. Canon Vixia HF R62 Lens Replacement: 5 단계, 이미지 1/1
    • Remove the 4mm Phillips #000 screw that was exposed after taking off the side panel.
  6. Canon Vixia HF R62 Lens Replacement: 6 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement: 6 단계, 이미지 2/2
    • Remove the three 4mm Phillips #000 screws shown.
    • There will be foam covers protecting some or all of these screws. These will need to be removed before you will be able to unscrew them.
  7. Canon Vixia HF R62 Lens Replacement: 7 단계, 이미지 1/3 Canon Vixia HF R62 Lens Replacement: 7 단계, 이미지 2/3 Canon Vixia HF R62 Lens Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, disconnect this ribbon cable by pulling straight out.
  8. Canon Vixia HF R62 Lens Replacement: 8 단계, 이미지 1/3 Canon Vixia HF R62 Lens Replacement: 8 단계, 이미지 2/3 Canon Vixia HF R62 Lens Replacement: 8 단계, 이미지 3/3
    • Repeat step seven (7) for the remaining three wires shown.
  9. Canon Vixia HF R62 Lens Replacement: 9 단계, 이미지 1/3 Canon Vixia HF R62 Lens Replacement: 9 단계, 이미지 2/3 Canon Vixia HF R62 Lens Replacement: 9 단계, 이미지 3/3
    • Grasp the top of the camera and pull straight up to remove the top panel.
  10. Canon Vixia HF R62 Lens Replacement, Lens: 10 단계, 이미지 1/1
    • Remove the 5mm Phillips #000 screw on top of the inner case.
  11. Canon Vixia HF R62 Lens Replacement: 11 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement: 11 단계, 이미지 2/2
    • Remove the two 5mm Phillips #000 screws near the display panel.
  12. Canon Vixia HF R62 Lens Replacement: 12 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement: 12 단계, 이미지 2/2
    • Disconnect the small bundled cable connector on the side of the lens cover by pulling it straight out.
  13. Canon Vixia HF R62 Lens Replacement: 13 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement: 13 단계, 이미지 2/2
    • Remove the lens cover by pulling straight away from the body.
  14. Canon Vixia HF R62 Lens Replacement: 14 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement: 14 단계, 이미지 2/2
    • Remove the three 6mm Phillips #000 screws shown.
  15. Canon Vixia HF R62 Lens Replacement: 15 단계, 이미지 1/2 Canon Vixia HF R62 Lens Replacement: 15 단계, 이미지 2/2
    • Remove the lens by pulling straight away from the main body.
    • Be aware of the small rubber gasket around the lens as it may come loose.
결론
Patrick Bennett
회원 가입일: 09/20/18
277 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 264
