소개
The motherboard might fail overtime due to age of device. The canon vixia hf r62 might not turn on, or have technical issues if the motherboard is damaged. Therefore it may need to be replaced.
필요한 것
Remove the strap by undoing the Velcro and pulling it through the thread points.
Remove the external battery pack by pressing down on the slide release and sliding it out.
Remove the two 3mm Phillips #000 screws.
Remove the 4mm Phillips #000 screw.
Using a spudger, disconnect the ribbon cable connector from the PC board shown in the picture.
Remove the four screws on the metal plate using the Phillips #000 screwdriver. Each screw should be approximately 3 mm long.
On the bottom of the metal plate, remove the two remaining Phillips #000 screws that are circled in the picture. Each screw is 3 mm long.
