주요 콘텐츠로 건너뛰기
Canon Vixia HF S10 Camcorder Audio Replacement
필요한 것
  1. Canon Vixia HF S10 Camcorder Audio Replacement, Audio: 1 단계, 이미지 1/3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: 1 단계, 이미지 2/3 Canon Vixia HF S10 Camcorder Audio Replacement, Audio: 1 단계, 이미지 3/3
    • Turn the camcorder upside down and remove the three 3x4 mm Phillips screws securing the black plastic case.
    • Flip open the LCD screen.
    • Remove the three 3x4 mm Phillips screws securing the black panel plastic case.
  2. Canon Vixia HF S10 Camcorder Audio Replacement: 2 단계, 이미지 1/3 Canon Vixia HF S10 Camcorder Audio Replacement: 2 단계, 이미지 2/3 Canon Vixia HF S10 Camcorder Audio Replacement: 2 단계, 이미지 3/3
    • From the inner corner in between the panel and the LCD screen, remove the two 2x2.5 mm Phillips screws and the 3x4 mm Phillips screw.
    • Remove the black plastic covering with your fingers. Underneath the covering, you will find a screw hinge.
    • Remove the 2x2.25 mm Phillips screw located at the top of the screw hinge.
  3. Canon Vixia HF S10 Camcorder Audio Replacement: 3 단계, 이미지 1/3 Canon Vixia HF S10 Camcorder Audio Replacement: 3 단계, 이미지 2/3 Canon Vixia HF S10 Camcorder Audio Replacement: 3 단계, 이미지 3/3
    • Using your fingers, remove the panel from the base of the camcorder.
    • After removing the panel, remove the two 2x2.25 mm Phillips screws located at the top right of the inside of the panel.
    • Using one hand, gently move the silver piece holding the speaker down while using the other hand to remove the speaker.
결론
Clint
회원 가입일: 03/03/15
101 평판
안내서 1개 작성함
Sam Houston State, Team 13-1, Blackburne Winter 2015 Sam Houston State, Team 13-1, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S13G1
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 420
