주요 콘텐츠로 건너뛰기
Canon Vixia HF20 Attachment Port for Optional Accessory Replacement
필요한 것
  1. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement, Attachment Port for Optional Accessory: 1 단계, 이미지 1/1
    • Remove the mini advanced shoe from the top of the camcorder.
  2. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement: 2 단계, 이미지 1/1
    • Unscrew the four 6 millimeter screws with the Phillips screwdriver.
  3. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement: 3 단계, 이미지 1/1
    • Carefully remove the silver plate with needle nose pliers.
    • Clean the silver plate with isopropyl alcohol and a cotton swab to remove any debris.
  4. Canon Vixia HF20 Attachment Port for Optional Accessory Replacement: 4 단계, 이미지 1/1
    • Reinsert the silver plate and the four 6 mm screws and screw them securely into their holes.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Taylor Morris
회원 가입일: 03/05/15
225 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 11-6, Blackburne Winter 2015 Sam Houston State, Team 11-6, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 467
