주요 콘텐츠로 건너뛰기
Canon Vixia HF20 Camcorder Strap Replacement
  1. Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: 1 단계, 이미지 1/3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: 1 단계, 이미지 2/3 Canon Vixia HF20 Camcorder Strap Replacement, Camcorder Strap: 1 단계, 이미지 3/3
    • Un-velcro the camcorder strap.
    • Remove the strap from the first hole by pulling towards the front of the camcorder, continue pulling the strap through until it is removed from second anchor point as well.
    • There should now be two empty anchor points.
  2. Canon Vixia HF20 Camcorder Strap Replacement: 2 단계, 이미지 1/3 Canon Vixia HF20 Camcorder Strap Replacement: 2 단계, 이미지 2/3 Canon Vixia HF20 Camcorder Strap Replacement: 2 단계, 이미지 3/3
    • Re-insert the new Velcro strap through the back anchor hole in the direction of the arrow (toward the battery end of the camcorder).
    • Then through the padded hand strap in direction of the arrow.
    • Lastly, pull the strap through the front anchor hole adjusting for your grip.
  3. Canon Vixia HF20 Camcorder Strap Replacement: 3 단계, 이미지 1/1
    • Once the fit is adjusted, secure by closing the padded strap.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Taylor Morris
회원 가입일: 03/05/15
225 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 11-6, Blackburne Winter 2015 Sam Houston State, Team 11-6, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G6
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 15
전체 시간: 521
