주요 콘텐츠로 건너뛰기
Cap Restoration
필요한 것
  1. Cap Restoration, Cap Restoration: 1 단계, 이미지 1/3 Cap Restoration, Cap Restoration: 1 단계, 이미지 2/3 Cap Restoration, Cap Restoration: 1 단계, 이미지 3/3
    • Wash the cap using an old toothbrush to remove residue and stains.
    • You can use dish soap or detergent to assist with the cleaning process.
  2. Cap Restoration: 2 단계, 이미지 1/1
    • Pat dry the cap with a towel to remove any excess water.
  3. Cap Restoration: 3 단계, 이미지 1/2 Cap Restoration: 3 단계, 이미지 2/2
    • Apply the hairspray to the front and inside of the cap.
  4. Cap Restoration: 4 단계, 이미지 1/1
    • Place plastic bags into the cap ensuring enough bags are used to give the cap some shape.
  5. Cap Restoration: 5 단계, 이미지 1/2 Cap Restoration: 5 단계, 이미지 2/2
    • Use a bowl or small pot to add pressure to the plastic bags and hold them in place.
    • Tighten the clip or snaps of the cap to fix the pot/bowl and plastic bags into place.
  6. Cap Restoration: 6 단계, 이미지 1/1
    • Set the cap aside to dry naturally. You can use an indoor fan to assist with this process.
    • Do not leave outside or near heater to dry.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hayley Rankin
회원 가입일: 03/05/19
248 평판
안내서 1개 작성함
Massey University, Team S1-G4, Rauch Summer 2019 Massey University, Team S1-G4, Rauch Summer 2019 회원
MUNZ-RAUCH-SU19S1G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 39
30일 전: 215
전체 시간: 18,768
