소개
If you need to replace the timer/on switch, follow this guide. The timer/on switch is essential to how long the coffee beans take to turn into coffee grounds. For this guide, you will need the Torx Security T10 Bit Screwdriver, the extension bit, and a soldering iron.
필요한 것
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
Strip the two wires of their black covering connecting them to the black box.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 7개
do you know where I can get a new black timer box?
Where can I purchase a timer/on switch?
Rob Gordon - 답글
Same question here, where can I buy this part?
Just piling on,has anyone found where to buy the Timer switch?
Same, looking for part number and/or where to buy the timer dial.
