주요 콘텐츠로 건너뛰기
Capresso Perfectea 260 Motherboard Replacement
필요한 것
  1. Capresso Perfectea 260 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • First, take the base of the device and flip it over.
  2. Capresso Perfectea 260 Motherboard Replacement: 2 단계, 이미지 1/2 Capresso Perfectea 260 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso Perfectea 260 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso Perfectea 260 Motherboard Replacement: 4 단계, 이미지 1/1
    • Unplug the wire going into the side of the motherboard
  5. Capresso Perfectea 260 Motherboard Replacement: 5 단계, 이미지 1/2 Capresso Perfectea 260 Motherboard Replacement: 5 단계, 이미지 2/2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso Perfectea 260 Motherboard Replacement: 6 단계, 이미지 1/1
    • Lift the motherboard out of the device
결론
Rohin Chander
회원 가입일: 04/14/15
101 평판
안내서 1개 작성함
Cal Poly, Team 6-17, Maness Spring 2015 Cal Poly, Team 6-17, Maness Spring 2015 회원
CPSU-MANESS-S15S6G17
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 13
전체 시간: 257
