소개
My Subaru's keyless entry buttons weren't working too well, so I decided to replace the battery within it.
This procedure is relatively simple, and the same basic principle can be applied to most other manufacturers' key fobs.
필요한 것
Unscrew the single Phillips screw on the back of the key fob using a #1 Phillips screwdriver.
The two black plastic pieces should separate, revealing the control module. Lift out the control module from the rest of the key.
There are four plastic retaining clips that hold the control module intact.
Starting with the smallest retaining clip, insert the flat end of a spudger in between the black and white plastic pieces of the clip in order to release its hold.
Rotate the control module to the next retaining clip, taking care not to accidentally clamp down the previously-released clip. Repeat the same procedure in the previous bullet to release the other two retaining clips.
Once all four clips are released, separate the white plastic piece from the rest of the control module.
Optional: Use the pointy end of the spudger to remove some of the gunk/buildup within the key fob.
Insert the control module back into the key fob, making sure all the buttons line up with the holes.
Reattach the two halves of the key fob on the side opposite of the key first, then continue until the entire fob is back together in its original state.
다른 24명이 해당 안내서를 완성하였습니다.
댓글 19개
All fine and good, except the identical looking key fob from my 2010 Outback uses a CR1620 battery. So much for the CR2025s I bought!
Nice, clear description of the process (which is very simple). My 2010 Outback also uses the CR1620 battery, not the CR2025 the instructions say. I would recommend disassembling your key fob and taking the old battery to the store to compare. You can still drive with the disassembled key fob; you just have to lock/unlock the door manually.
Great instructions! However, just like Mark and Janet, my 2010 Legacy keys had a CR1620 battery. Also, there were 4 plastic clips on step 2. Thanks for the guide!
Apparently the instructions have been updated since the above comments, because they now call for the CR1620, which is what I bought, and they work perfectly!
The instructions and photos are very clear, easy to follow, and accurate. I was very pleased to find this site and realize that for about 15 bucks total I could replace the batteries in both our 2010 Outback keys - I had imagined we'd have to get new keys or at the least take them to the dealer for a highly pricey replacement. Thanks, ifixit!!
Question, I replaced mine but it still doesn't work. do I need to reset the system?
